BLOW up - Survey
Mileage ...........................................~73,000
turbo ...............................................stock
Intercooler........................................stock
Boost level .......................................unknown
Bov...................................................stock
octane .............................................91 octane California crap
Chips ...............................................Supercraps I mean Superchips
wastegate ........................................stock
boost control ....................................Superchips mbc
A/f monitoring? .................................none
Injectors...........................................stock
detonation monitoring? ......................stock (none)
Head gasket type ..............................original
Intake type .......................................stock
Air filter ...........................................K & N
Oil ...................................................regular dinosaur juice 20w-50
Damage............................................Cracked piston lead to wrist pin retaining clip failure. Wrist pin worked it's way into the cylinder wall ruining block.
Cause...............................................Most likely detonation caused by too much boost with stock fuel setup, poor chip tuning, and the PO unaware of what was going on.
Mileage ...........................................187,000
Intercooler........................................LR stg1
Boost level .......................................17psi
Bov...................................................Strat. hyperboost (adj)
octane .............................................93/94
Chips ...............................................Guru
boost control ....................................LBE
A/f monitoring? .................................narrowband
Air filter ...........................................stock
Oil ...................................................mobil 1
Damage............................................spun #2, scores in #3, burnt valve
Cause...............................................PO sold me the car as 87k not 187, lied about maintenance. failed wastegate line (dryrot) caused 23-25psi spikes, burnt an exhaust valve, etc
Mileage ...................... 140k
turbo ................................K26/6
Boost level ......................................standard
octane ............................................US93
Chips ............................................standard
wastegate .......................................standard
boost control ...................................standard
A/f monitoring? ................................none
detonation monitoring? ......................none
Head gasket type ..............................standard
Intake type .......................................standard
Air filter ...........................................standard paper
Oil ...................................................Unknown (had the car less than a week)
Damage ............................Spun #2 Bearing
Mileage ...........................................38,000
turbo ...............................................k27/8
Boost level .......................................16psi
Bov...................................................LR performance bypass valve
octane .............................................91/93
Chips ...............................................Autothority stage 2/ Mafterbuner.
wastegate ........................................Tial 38 mm
boost control ....................................MBC
A/f monitoring? .................................ZT-2
Head gasket type ..............................Wide fire
Intake type .......................................Autothority MAF
Air filter ...........................................K/n
Oil ...................................................Red line 10w40
Damage............................................Bent intake and exhaust valve (#1)
Cause...............................................Timming belt broke due to over tension.
Mileage.................................~73,000
turbo.....................................stock
Boost level..............................16.5psi
octane....................................93
Chips......................................Guru
wastegate...............................LR DP
boost control...........................Blitz SBC-iD
A/f monitoring?........................Rennbay AF9
detonation monitoring?.............No
Head gasket type......................original stock
Intake type..............................stock
filter........................................stock
Oil...........................................Castrol 20w50
Damage...................................blown headgasket
Cause......................................too much boost for 17 year old headgasket to handle
Mileage.................................~77,000
Boost level..............................15psi
octane....................................91
Chips......................................Vitesse
Head gasket type......................MLS
Damage...................................turbo
Cause......................................nut on impellar shaft backed off. I think this was due to playing with the EBC which allowed a brief boost spike to 21psi.
