Turbo
I would ask John the last question. More importantly the kit is what makes his package not just the turbo
Hope that helps
regards
Ed
Hope that helps
regards
Ed
Originally Posted by silverbullet
Does a K26/7 fit without modifications?And will a Tial 46mm go with it? What turbo comes with the Vitesse kits?
- Modify turbo water outlet pipe to clear larger compressor
- File down the compressor housing and/or TB spring bracket to clear larger compressor (this depends on the compressor type and the way you clock the turbo).
Vitesse Turbos start life as Garrett Hybrids..
