DME/KLR pin numbers
1 Post
does anyone know the DME pin numbers for the air flow meter input, injector duty cycle and knock input?
My Blitz boost controler can monitor 3 functions and I think these are the most vital to know given the controlers capabilies.
Also is there going to be any problems splicing into these signals?
OOOHH a new list of smilies...but what in the hell is this one suppsed to be?
Thanks in advance
Sean
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Thanks in advance
Sean
Injector timing signals: #3 & 4: DME pin 14, #1 and 2: DME pin 15
Knock sensor: KLR pins 11 & 13.
HTH
1 Post
THanks for the response Don.
hummmm the knock sensor has got me scratching my head. do you know the type of output it is? I know it is a pulse but is it one wire negative and the other positive?
And if I were to hook up just one pin of the injectors it would be a pulse but any adverse effects on the actual out put to the injectors?
Don't know about either of those. I suspect that the knock sensor puts out a positive/negative pulse. The sensor wires are within a shielded cable, with the shielding connected to ground, so neither side of the knock sensor is grounded.
