Video: 0-200 km/h in my 951
#31
Originally Posted by Konstantin
you mean 100 to 200 right?
0-200 would be too fast ;-)
Konstantin
Konstantin
#32
hehe, ok I fixed my post... 100-200. It was late .
I used VP MS103 unleaded fuel, rated at 103 octane (R+M/2). The turbo was a T04E 57 trim with the #8 hotside and stage 3 turbine. I've run 28psi on stock internals without any problems. The only upgrades I had at the time were the Raceware head studs, wide fire head gasket, and o-rings to keep that gasket in place.
And yes, timing, and fuel must be correct to ensure there's no detonation.
It really doesn't feel that fast. I think we get desensitized to the speed pretty easy haha.
True.
Higher octane fuels generally burn slower, and has less power during the burn. However, because the knock threshold is higher, you can increase boost/cylinder pressures, and easily make up for that lost power. Regardless of what fuel you use, if timing and air fuel is off, you're gonna detonate.
Good luck running 25psi on pump gas with our motors. You can probably do it with very little timing, but it would melt your spark plugs and exhaust valves pretty damn quick from the high EGT's! It's impossible to run 25psi reliably on pump gas. If it was that easy, all the manufacturers would be doing it.
Originally Posted by daniel951
rage when u made 450rwhp on 25psi that was on race gas and what turbo? Is it safe enough to run 25psi for a dyno run. I was reading about what danno said and he said it doesn't really matter on how much boost u are running but your a/f ratio must be on.
Originally Posted by Duke
Great to see other 100-200 times, Rage the 2.5 litre 25 psi time is simply crazy!
Originally Posted by hosrom_951
You can hit 15psi on pump gas and have detonation (bad a/f ratio).
Higher fuel ratings, give more power, since the burn faster (?), you can also hit 25psi on race gas and still get detonation......
So, basically, if you can get the a/f ratios correct at 25psi, you'd be safe. The a/f ratio is what makes runnin rich (bad for piston rings) and running lean (detonation occuring, but depends on the loads, boost etc) so, yes.......you can get 25psi boost on pump gas IF you'r a/f ratios are correct
#34
Originally Posted by porshhhh951
video didn't work for me.
It's in MPEG-format straight from my Sony digital kamera.
#37
Originally Posted by rage2
Here's some of my 100-200km/h times from old videos.
11.0s 12psi 2.8L ~365whp
10.1s 15psi 2.8L ~400whp
8.8s 25psi 2.5L 450whp
Konstantin
#38
I looked at the speedo. It was actually 60mph to 125mph (96km/h to 200km/h). Loaded the source high res video clip and did a frame by frame analysis. One of the better way to figure out acceleration times .
#39
Monkeys Removed by Request
The video wouldn't download when I tried it before but, it worked for me last night so it's all good.
I am going to test my 60-120mph times myself and see where I stand.
8sec's sounds pretty insane. I think I will hope for 11 or so.
#40
That will definately clear up the 300whp debate with your car!
#42
dyno will be the only thing that clear's that up
and it's coming.
and it's coming.
