I'm going to do a radiator system flush, any tips?
The reservoir fluids is a dark black color so I'm going to drain the system and run some Prestone flushing agent with water. I figured I'll get the front up and start looking for drain plug on the radiator and I'm guessing I should pull the one on the block, any ideas where that is?
muchas gracias, should I drain the radiator first and then the block, and will the radiator tank on the driver's side of the engine bay drain with the radiator or will I need to idle the car with the heat on while its draining?
Just use water to flush. That dark color is kind of weird. Maybe some misguided PO used some mechanic in a can solution to try to fix a leak. How long have you owned the car?
I bought some Prestone flush at AutoZone, you drain the system, then drop this stuff in and fill with water. Then after you drive it about 3 hours total (over a period of a few days, not all at once) you drain everything and refill the system with correct fluid.
I dunno man, I'd have to hear from more than one mechanic on this before I used it. My car doesn't have any deposits in it that I can see, what are they exactly?
I just replace my coolant every two years, and my system runs great. No deposits here.
Maybe your mechanic is thinking about old rusty V8 blocks or something.
I'm just skeptical because there's so much stuff out there that does nothing or is used unnecessarily.
