what rpm does boost kick in?
Originally Posted by hosrom_951
Sorry to go OT a bit, does the same apply for the SS brake lines?
Originally Posted by NZ951
Oh was he suggesting if SS brake lines come with hose clamp fittings?
Originally Posted by 84black944
Hey NeedPorscheSpeed i read about the Ian special and see it has the vitesse stage 2 kit are you satisfied with it? are you required to do something else before you can use the kit? And does it make the power they say it does? I am just asking these questions b/c i might want to get a kit from them.
I am quite satisfied with the Vitesse Stage 2 kit. I didn't actually install the kit, but, Ian, the car's previous owner and creator, said that the kit was not difficult to install. I have heard nothing but rave reviews about John's customer service (he is Fast951 on the board), so if you were to encounter difficulty during the install, I'm sure that he would help you leap over the hurdle. As far as power goes, yes, it lives up to its claims. Ian took the "Special" to a dyno a month before I bought it, and, at 17 psi on pump gas, he laid down 330/330 at the rear wheels. Bear in mind that this was during 95 degree summer heat and the dyno's fan was faulty. Good luck, and feel free to PM me if you have any more questions.
UAE Rennlist Ambassador
Originally Posted by NeedPorscheSpeed
I just saw this post of yours; I missed it before I went to bed last night.
I purchased John's kit as well awhile back, ran into some trouble, and John was that of a stand up guy to step in and resolve the entire problem. So ya he is a stand up guy, and keeps his word. So if your looking for a kit to purchase, talk to him.
Originally Posted by fast951
Just to clarify the sort of problem v944god had. The kit got stolen after delivery..
I have a '86 951 with Guru 15psi chip set, Tial 38mm wastegate and no cycling valve, FULL BOOST in 3rd gear at 3,200. Without the cycling valve in plus the wastegate, it does build boost sooner though.
You people with vitesse stage 2 kit, what rpm does it hit 1bar/14.5 psi? (with or without quick spool option & other engine mods?)
Going to order a stage 2 kit from you in the vinter john/fast951
