Brake Pads and Transmission Fluid...
Hello,
My passenger side front brake pad squeaks A LOT!
What can I put on the brake pad to eliminate the squeeks?
How do I remove the brake pad, what do I put on it to make the squeel go away, and how do I put the pad back. I have 928 S4 brakes.
Also,
I have a 1989 951, what kind of trasmission fluid do you guys recommend, and how do I drain and fill the fluid?
Thank you.
Also,
Thank you.
UAE Rennlist Ambassador
For fluid:
http://www.clarks-garage.com/shop-manual/trans-06.htm
There are brake shims for the pads, i use Mintex pads and made the squeel go away.
Pad replacement:
http://www.clarks-garage.com/shop-manual/brake-02.htm
Pad replacement:
Try Permatrex Disc Brake Quiet, it works great for my pads.
I'm looking for a recommendation on transmission fluid as well for my 89 with LSD, if anyone has any suggestions, please post.
