Tial WG doesn't fit - need advice : UPDATE
#61
I think you need an EBC to hold the boost, without a closing pressure signal the manifold pressure will push the wastegate open. Anyone with an EBC not able to hold boost to the red line?
Tony
Tony
#62
How's the pressure differances between low and high gears with a MBC and a Tial?
With a MBC and stock WG I get really big boost differences which makes it nearly impossible to adjust good A/F ratios for all conditions. Either too rich or too lean.
A EBC is probably the only solution, but I'm wondering if this problem is less evident with a better wastegate.
