Suggestions for making a DIN style pocket guage panel
I have decided to attempt to make a gauge panel that will fit in the DIN pocket or "sunglasses holder" area of the console. My decision is based on two reasons: (1) I have a remote whister radar currently in the OEM pocket and I intend on making a cut out on the panel; and (2) I may want the gauge panel to be polished aluminum (silver) to match the screws in my momo wheel and metal turbo shift insert. I have done several rennlist searches and have seen the panels by 9xauto and Lindsay racing - but believe I would be better off making the panel myself based on the radar cut-out and the fact that I would prefer to try the polished aluminum (silver). I am sure someone will chant in with a "rice" comment - I don't have a flashing LED shift ****, love the Audi TT's interior, and believe the silver adds to and modernizes an otherwise dull interior. Any suggestions on sources for plastic or a sheet of polished aluminum? Anyone have a stencil by chance? I appreciate all comments -Thanks -
Jeremy
Jeremy
I made mine out of a piece of black ABS plastic. It's really easy to machine and very cheap. If anything you could use this as a good template for the AL.
HTH
HTH
I've made a couple of them. One was for my boost and A/F ratio gauges, and the other is for my AVC-r. I used a sheet of aluminum that I got from a local hobby shop. I've never polished them, but it would be easy to do so. Mine got painted black with trim paint. One word for detail cutting: DREMEL!
Check the ricer-boards and suppliers. A DIN-sized gauge-panel is a common off-the-shelf item. You can get it in aluminium, titanium, carbon-fibre, leather-covered with the hide of your choice, ABS or PVC plastic, walnut, even glass!
I took a 968 pocket (it comes with a clock), removed the clock-and filled in the clock mount with Bondo. I then cut out for the boost gauge, and finished it by painiting the whole thing black. I still have the pocket (i use it), and I have a gauge panel that looks somewhat like the factory did it.
Thanks all for your responses - I was able to pick up a thin piece of polished aluminum at Lowes last night. I will attempt it this weekend. Jason_86_951 - I was a little confused by your post - do you have a stencil that you were attempting to upload? -
Jeremy
Jeremy
BTW the easiest/cheapest way to build that panel is to get a DIN black front made to use when a car stereo is not present.
You can pick one up for around $3-4 and the size is alreay perfect and as a bonus they have clamps on the inside that holds the panel in place.
