Advice Required!! Which MAF System is best Bang 4 Buck!!
#31
I wish i could afford Link stand alone- but the cost is more than 2x that of MAF+piggyback. The Link is definatly impressive though. I like the fact it uses the stock sensors- so you can fool the smog cops.
#33
"As far as duty cycle goes.......This is dictated by the maximum voltage of the MAF which is directly related to the size of injector".
Autothority unit:
The only thing that dictates injector duty cycle is the size of injector vs the air flow through the engine; it has nothing to do with the sensor being used.
"When the sensor tops out its voltage signal, your injectors reach 100% duty cycle."
Again, they don't have anything to do with one another.
"Put a larger injector in and your voltage signal drops which means you get more range out of your sensor and thus a lower duty cycle"
Your voltage signal from the MAF is determined by the mass air across the hotwire; changing injectors doesn't alter that. You will get a lower duty cycle, but you have to rechip so that the same voltage signal communicates a shorter injector pulse width.
"If you run out of range on your sensor, you install a larger injector"
Autothority unit:
If you run out of range on your sensor, the electrical engineer has to recalibrate the unit.
For example: Instead of 5 volts max corresponding to 20 kilograms of air per minute (about 425 hp), it can be changed to 5 volts max corresponding to, lets say, 30 kilograms of air per minute. That does, however, render the unit less sensitive leading to potential drivability problems
Autothority unit:
Autothority unit:
