Snow Performance Water Injection
Another potential problem is with varying water pressure , it has to be perfect 100% of the time otherwise if you have too much water in the cylinder you are basically "putting the fire out" too little and you could detonate.
I love the idea and theory behind the WI but its IMO a little finicky for proper everyday application.
Now methanol is a different story, it burns better and cooler than fuel, but it is very corrosive and needs a completely seperate injection system that would probably need replacing every 5-6 years due to extreme corrosion.
Originally Posted by B951S
I just ordered a stage II with progressive controller. Matt Snow said they have designed a fail safe flow switch that goes right before the nozzle that can trigger saftety devices / drop boost in the event flow stopped. It should be ready in a few weeks. I plan on hooking up this swith / level swith and motor power such that if any of the input are not good, the relay supplying power to the boost solenoid will unlatch, dropping boost back to WG level only (10 psi). Matt reckoned that on simiar high boost 4 cyl turbos, serious gains were realized from timing / boost increases... to the tune of 20%. We'll see.
The failsafe switch is a flowmeter impeller type with pressure also I think, Sound like the ****. As far as finiky, I think if you have closed loop knock and other failsafes you can minimize your risk. I have been wanting to experiment with it for a while anyway so here goes...
Drive-by provocation guy
With timing advance and being able to run about 2-3 more psi safely, 20% at the wheels is about right, if not a little conservative.
Maybe another group buy?? I am sure Matt would allow your purchase to be retroactive and give you the group buy price.
TRB0 GUY
My buddy developed a system for a 930. They are working on a 951 system soon to be done. Check out their performance gains:
http://www.heibar.com/
Kevin,
if somebody wants to be a real *** about it, your buddy could possibly have legal trouble.
He just copied info right from the aquamist literature, and it looks like he's just using aquamist's pump and creating his own overpriced system. Aquamist had to research all the numbers as far as heat removal ability.
As far as the basic concept is concerned, the same ramble just keeps getting repeated from one party to the next: very high heat absorbtion, increased VE, blah, blah, blah. Then everybody treats this over-generalized info as technical gospel, and some of it is not even correct.
For example: the blurb about water slowing down the burn rate like race gas.
Octane of the gasoline has nothing to do with how fast it burns, and secondly, if your charge in the combustion chamber burns slower you have less power potential.
Here, here TurboTommy, but let me ask you this...with some alcohol / methanol in the mix it I thought it burned more slowley thereby causing peak cylinder pressure to occur when the crank is rotated more thereby increasing torque...... Anyways, be that as it may, I'll slap it on and see how she blows.....
Why would you ever pay $2300???? Oh, I forgot it's for a Porsche.
There are kits all over the place for about $300 to $500.
If anyone wants to build there own...here's the link:
Cost: about $289 total Universal kit is at the bottom http://home.att.net/~alkycontrol/page1.htm
I would be keen on the GB, but I want to see an installed one first, mounting areas etc, preferably with a link attached to it
Anyone got performance gains or other relevant data with this system on a 951?
