Still can't find source of problem!!!!!!!!!!
07-17-2004, 03:37 PM
UAE Rennlist AmbassadorRennlist Member
They should be long? i made then really short so the hatch would catch. SHould they be long?
07-17-2004, 03:40 PM
AddictRennlist Member
Here is a picture of the two nipples without the vacuum hoses. the back of the engine is towards the right.
07-17-2004, 03:53 PM
What smell is it? Fuel? Exhaust?
07-17-2004, 04:47 PM
The pins should be just long enough to catch the latch completely. Just dial it out 1/2 turn at a time until it catches completely. You should not be able to pull it open without using the key
07-17-2004, 11:15 PM
I shall look at the hatch pins tonite. I replaced that valve a week ago, it was new and did not have any RED marks :S
07-17-2004, 11:16 PM
It is not a fuel smell, nor is it an oil smell. It MIGHT be a slight exhaust smell, it smells weird that's all.
07-17-2004, 11:17 PM
eclou: If i took out those pins completely, should they be half way in?
07-18-2004, 01:50 AM
No,
just back them out longer just enough to catch completely. Not sure exactly how long but its about 70%
07-18-2004, 02:15 AM
You may want to check for any cracks on your headers. When I had a crack I would get exhaust fumes in the cab. This would happen on wot.
07-18-2004, 04:24 AM
But wouldn't make fumes in the cabin at all times? even with the hood open?
