Koni Yellow Adjuster
Originally posted by Cyrus951
I .....The PO lifted the front end of the car via the Konis, how do I lower the car?
Take a look to see how far down the perch is set - to adjust, you should use spring compressors to remove the spring tension, then unlock and move the bottom perch. Use something like PB Blaster or WD 40 and a wire brush to clean off the threaded sections before adjusting.
The rears are more work as they involve adjusting the eccentric on the trailing arms. Just do a SEARCH on the forums, but take a look at the fronts to see how far down the setting is first.
My car is set up on the lowest settings and I have no problem clearing driveways etc in my area.
Could setting the konis too stiff effect the springs? Could it ruin your stock springs????
poormans9fitty1
No not the Koni's....the bistein cup might..
poormans9fitty1
