WTB 86 944 TURBO ENGINE/DME HARNESS
Check out a new one from Kroon.
I should receive my standalone ecu and harness in a week or so. If that all goes well I won't have use for my 951 harness. Everything was working fine when the car last ran about a month ago. Hasn't been running due to other things I've been doing to get it ready. Some of the connectors were a little crispy on the ends and I replaced them using the solder seal heat shrink connectors. Other than the ends where more exposed all the wiring looked good. I have it wrapped in 300 deg heat tape now. I don't really want to get rid of it, but if you are having trouble finding a harness I don't want to hold on to something I may newer use.
