Fire Extinguisher mounting where?
Going to buy a fire extinguisher tomorrow, too nervous with all these fires happening! A powder one was best right? Were abouts to mount? I want it easy to get to but not obstructive, where have you guys mounted one?
NZ
I've mounted mine off the front of the passenger seat mount brackets, using the original seat bolts. Don't like drilling holes in my Porker.....
Will post a pic if you need one...
Rob
Rob
The Brey-Krause seat mount is a nice piece, might be too pricey after shipping and any import fees though. A little fabrication can make one like it, probably like Rob's? I mounted mine in front of the passenger seat for easy access. At least I did until the Recaros went in, the B-K mount doesn't work with the Recaro sliders. But I recently got a Redline bar in, so it'll get mounted to that.
I keep a Halon extinguisher in the car, powder will create a huge mess and may damage the engine if it were to be sucked into the intake.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
If memory serves me, I read some threads that Stable Energies mount has the advantage that it moves with the passenger seat. There's also a guy on eBay (actually a VW guy) who's been selling a simple bracket that mounts to the rear passenger seatbelt bolts -- I got one, but haven't had the chance to get a FE.
Also, rather than Halon, Halotron is more readily available these days (for environmental reasons).
Yes, you want Halotron, it is similar to Halon but it is more environmentally friendly and cheaper. Powder will destroy your wiring in case of a fire and make a huge mess.
As far as a bracket, if you have the non-power factory passenger seat, I will sell you my B-K bracket. I just moved my Recaro SRD to the passenger side and can no longer use the bracket.
Let me know if you want it and we can work out a deal...I don't know if there are problems with shipping to NZ though.
Max
Max
I had to sell my Stable energies one because I got aftermarket seats. Found a guy who sells a machines piece of alluminum that mounts on the rear seat seat belt mount points.
here is one.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
here is one.
NAY! I took out the rear stock belts since no one can get back there anymore, and I bought eye bolts that screw right into the stock holes. This particular mount is thin metal, like 1/16", and its in between the eye bolt and the stock hole in the rear seat. I have clip ends on my 5 point harness that clips into the eye bolt and goes up around a harness bar. This mount works great. Got the eye bolts and harness's from racer wholesale.
Andrew
I mounted my Halon on the kick portion of my rear passenger side seat
(where the person seating in that seat, heels would be ...
The extinguisher came with the bracket it fits nicely there and is in reach
while you are in the drivers seat. ..
If you want I can send a pict but it won't be until tomorrow ...
regards
Ed
regards
Ed
Max shiping is not that much with USPS, does it fit a variety of sizes? I am going with the powder version here as it like 20 opposed to a truck load more! And I dont mind having to clean after a fire, I will just be happy its out. I will do a serach on those brackets and see, I have a non power passenger seat.
