guru chip
i have an 18 psi chip that danno sent but he hasnt sent the boost controller and wastegate shims yet...my question is ...can you install the chip and drive the car with out the boost controller and wastegate shims?
If you have no way of turning up the boost then don't use the chips - they won't do anything for you but make you run rich (and slower than stock, most likely).
thanks everyone ....ill wait till i get the rest of the kit
