I need a Rogue file for Rogue Direct DME - 3L 80Lb.
See my other post. The tune for my 3L 951 with 80lb injectors and Rogue Direct DME appears to be gone due to expired battery that I did not know to replace.
I might have the file in the hard drive in an old laptop that won't start now. Maybe the hard drive can be saved, don't know. PC just won't start at all, doesn't seem like a hard drive failure.
Maybe it's time to replace with something more modern, but I have a track day scheduled Friday and the weather is predicted to be perfect!!!
I have saved all the m-tune files from rougetuning.com if that might help
https://www.dropbox.com/scl/fo/q3al1...ot2stsm4y&dl=0
Thanks for the replies and help. I can't seem to get my new PC to communicate with the direct DME. I did (attempt to) replace the battery, but I do not have any confidence in the solder joints. Had no luck communicating with the DME after installing new battery and installing in the car, and car would not start. Stuck an old chip in the ECU, car started.
Not sure if there is a way to buy a Direct DME. Apparently at one time this PC did communicate with the car, I could see evidence of a file for this specific car in TunerPro, but no connection using TunerPro RT
Also, I did find a few files in the old hard drive, and downloaded some from the link gicke provided (Thank you!)
