shim wastegate or just replace?
Ok. The 18 psi chips are in, new boost gauge is in, Reliaboost is in, cv is bypassed correctly, all new vacuum lines, 12 psi is all I'm getting. The car pulls great and runs great. Gas mileage went up with Guru chips by several MPGs! I think everything is working as it should but I need to put down more boost. I haven't gone through the trouble of shimming the wastegate yet. Is the shim job onerous enough that I should just order a rebuilt one from Danno so I'm sure I won't have to do it again? The money isn't as big a deal as finding the time.
Drive-by provocation guy
Well, I had such a pain with it I am glad I just went with the GURU wastegate instead of shimming then changeing out the WG down the raod anyway. I am running the 18's also and makes and holds no problem, assuming your turbo doesn;t run out of steam.
Todd,
Thanks for the tip. Despite the high-performance facade, I'm a tree hugger at heart so if cat bypass means what it sounds like, I'm going to hang onto it for now. Now a free-flowing cat is tempting or a catalytic test pipe...I think I need more research before I make an exhaust decision.
Get advice from Danno on reliaboost. I use a LBE and my OEM, yes yes yes i know they suck, boost guage runs up to 2 bar (slightly under 15psi) and sticks. I put on an accuboost and with the **** completely turned in all the way, i would touch 2 bar until about 550 and then it would back off to below 2 bar. i have a stock WG.
i would definitely check the boost controller first.
Originally posted by richmason
thanks for the perspective. I'll call Danno today. Elon, I may take you up on that - much thanks for the offer. What color is Flamingo Metallic?
Thanks,
Thanks,
Originally posted by azmi951
where is the best place to get a tial?
For good customer service and speedy delivery try MySwiss
Steven.Wistuba@ypg.com
(includes adapter plates)
