951 2.5L with T04E 60 @16 PSI?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Here you go -
http://forums.rennlist.com/upload/dy..._med_boost.jpg
Its hard to read the graph but the HP peak is 370 and the torque maxes out at 350. This is at 19 psi. At 15 psi the peak HP was down to 350.
This was on a stock bottom end 2.5 with fairly stock head, tec3 engine management, intercooler pipes, 72# injectors, test pipe, Tial 35mm. The turbo is a To4E with #8 hot side.
Here's the dyno the previous owner of my turbo gave me. It's a T04E 60-1 Hifi with a #8 hotside. The upper run is at 15psi. There's a fair amount more done to the car though. See the link in my sig.
![](http://mywebpages.comcast.net/brutalracing/pictures/dyno1.jpg)
ok check this for a 968 Turbo S vs the 951
http://www.968turbo.de/968tsdyno.html
and these are the data for the 968 TurboS
237KW@5310(porsche claims 225@5400)
and 519NM @3730(Porsche claims 500 @3000upm)
dynoed was in third gear so in 4th or 5th would be better since the boost was only 0,85 bar
Konstantin
![](http://www.968Turbo.de/dyno3.jpg)
![](http://www.968turbo.de/968tsdyno.jpg)
Konstantin
