OT:how can i add pic to signature?
Sorry tom,
the head was on before i put the intake and i did not do a dyno before because the car was my dads at that time and he never took it to the dyno.
the car also had a big problem with the prior set up "huntley maf" and i just swapped it out with guru's map and installed the manifold that was sitting in the box.
sorry
sorry
cantresjr:
Those two photos you got on the bottom are still WAY too big.
a suggestion to make them smaller: Crop the first photo so that only the supra and 951 are visible. I mean crop them reallly tight. And then below that, just put a link to your engine bay photo, full size.
That would look even better than my sig which is due for an overhaul too.
Thanks Rich, lets see if i can pull that out.
I'm the FE, dying breed for shure but loving every minute of it. especially in the mighty Herc.
