oil dipstick o-ring
oil dipstick o-ring
anyone know what size this o-ring is? I called the dealer to order some parts: the oring, 3 crush rings, 4 nuts and bolts and they wanted 314.11
nz are there 2 orings on the dip tube?? I pulled the turbo and my dip tube came up with no resistance so I think that I may not have any orings on my dip tube
900 174 044 40 is the part number for the o-ring. I don't know the exact size and I just put my dipstick tube back in and really don't feel like removing it. What nuts and bolts are you looking for? I know the M10 locking nuts from Porsche are about $12 a piece but $300+ is way out of whack. They must have included something wrong or looked up a part number incorrectly.
People use many o-rings on the stick! I used a stock one which slides over the tube, and a 16mm on the flange, as per Danno's instructions. Not leaks now!
PS, look for your o-ring split or broken the the cavity where it sits, thats where mine turned up!
I've seen some lazy mechanics just completely coat the outside of the dipstick-tube interface with the oil-pan with silicone... I suppose if you get the surfaces clean enough and smear enough silicone on the outside, it won't leak. Not exactly elegant, but I guess that can work.
That 16mm sits on top of the oil-pan and is under the outermost step on the flange on the dip-stick tube. Smear some Yamabond on that gasket and flange. Then after it's inserted in the oil-pan, push down on the dip-stick tube as you tighten the bolt.
