Got a baseline dyno run today...
#31
However a manual boost controller is a better approach...
John - I know that you are a well respected tuner but I have to disagree. I think this is a recipe for disaster with the APE setup unless you swap the chips. The main complaint from people is not the rich midrange but the lean upper limits (at least what I have seen). I dont think there is any way you can extract max power out of the 951 with the APE product but you can have a reliable amount because the chips are built that way. Not max power but good power at a reliable level.
FWIW - I think we are thinking the same thing. IPSC is not going to be able to tune this on his own without a lot of help. There appears to be a problem with the car (other than the APE stuff) as it is not making enough boost and runs far too rich. The dyno numbers are very low but without a graph all is speculation and shots in the dark.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
#32
I don't agree running rich washes the cylinder walls. It's a rich mixture, not liquid gas. The worst it will do is foul plugs. Mine's running rich and the plugs look fine.
#33
I was thinking the same. I have only heard of cylinder wall washing on idle. Have anyone here actually experienced this when running rich in midrange? I would assume that some small amount of extra gas is evapourated and purged, just think about the temperatures involved.
(Not that I think it is a good idea)
Bengt
Bengt
#34
However the AFR must be correct across the RPM.. Is it possible to get perfect AFR with APE chips?? I think we agree on the answer!!!
#35
John, I think we probably do. I think you still missed what I was saying. Perfect AFR is kind of a misnomer anyhow (I know you know that). However perfect AFR is just a misfire or malfunction from detonation and breakdown. The APE products are a little rich because that dials in some safety. If he was running 15psi (like the chips are designed for IIRC) then it should not be anywhere near this rich. I think we both agree that there are probably multiple problems in this case.
I did say above that there is no way you will make max power from the APE setup. And I also think we agree as to why.
#36
I am certainly not an expert in the same way that many of these others are, but I made the switch from APE to Guru a few months ago. I wanted to switch to a MBC because I was getting boost around 17-18psi with the jetted banjo bolt. I assumed it was a weak WG, but I wasn't sure. Regardless of the cause, I wanted to have more control over the boost.
I also noticed that I was running a little lean on top and rich in the middle according to my Lindsey A/F gauge. It definitely didn't feel smooth. I don't know that it is a bad map overall, but it certainly wasn't matching my car and boost level
So I switched to Guru + Reliaboost...world of difference. Not only was it more powerful, it was also considerably smoother. My A/F was closer throughout and my idle was smoother too. I had more power below boost, too.
I know there is a little more power and smoothness to be had if I went with a piggyback. Just haven't taken the plunge.
I would suggest doing one of these three things:
1. Stock airbox + stock chips + stock boost
2. Stock airbox + Guru/Vitesse chips + MBC/Reliaboost
3. MAF kit with piggyback (Vitesse, SFR, Lindsey, etc.)
Good luck!
Max
Good luck!
Max
#38
I have an adjustable FPR and a fuel rail gauge so that isn't a concern. Here is what I am going to do. Get the FPR in and see what fuel pressure I actually have in the rail. For stock injectors Is 36 lbs right? Then get a boost meter in to see what I am reallly running for boost and go through all of the vacum lines and hunt for leaks.
IPSC
IPSC
#39
There are three different APE MAFs with three different calibrations. They they have a corresponding matching chip. These are mapped for the stock K26 turbos and APE doesn't distinguish between the K26/6 and K26/8. I think they just dump in a little extra fuel and kinda blend both of them together. Going up to a K27 chip, they actually don't have it customized for the particular MAF sensor anymore. They just dump in 15-25% more fuel than the K26 chips. This might be why you're seeing such a rich mixture because the K27 actually has a little more lag than teh K26, thus lower flow and requiring LESS fuel in some of the chip's fuel cells. Then there's also the difference in flow-rates betwen a K27/6 and a K27/8... ahh... so many variables...
If you want to just give me some air-fuel ratios in 500rpm incremetns, I can get you a fully-optimised chip for your configuration. That's what we did on Ski's (Bret) car a couple years ago when he took out his Lindsey-363 kit and installed a K27.
