Clutch
Monkeys Removed by Request
how werid describe it a little better. Stock clutch should be grabbing half way through the pedal. Say the pedal moves 6 inches total....at about 3 it should be grabbing just fine. When the clutch starts to run out of life that "feel" spot as I call it get's moved further and futher to the top. Then finally you press down the clutch and nothing happens at all.
