Is OPRV a common failure point?
Are OPRV seals/OPRV unit supposed to be changed at a set interval? My 951 is leaking, but interestingly enough the only leak points are the oil pressure sensor and the oil pressure relief valve.
I think it may have to do with the fact that I have recently welded in an HFC to the exhaust and I think the increased back pressure is the likely cause of the accelerated oil leak.
