Expert help advice needed!89 turbo DME and KLR to 88 non S???
My DME seems like it's toast!! can I use a 89 turbo S DME on my 88 NON S 951,and if so what changes do I need to make? please help!! I am asking anyone that has knowledge becouse a lot of people here have great knowledge and I would not want to ask a specific person and there by undeminding others knowledge..becouse like I sayed..I learned a lot from all you guys!!...all feel free to input advice! Thank you for your time!
Unaffiliated
Amatuer input here... I have an 89 DME and an 86 DME (I wanted to try early chips I had access too) that I can swap out, plug and play in my 89 Turbo. The chip sockets are different but the units are swapable.
so say I have an 88 non S turbo, and take a 89 turbo S DME and switch it out it iwll work just like that or do I have to change the chips ?
Ummmmmmm more than that. You will get some money for you KLR unit and old harness, and air box / AFM etc . Call Neil at performance developments. He can get you a quote, or check out their site. I am surprised you dont have one already actually. Huge flexibility.
’89 DME have a different program in the chip. This program is designed for the bigger turbo which can be found from S models. I suppose also KLR chip has a little bit different program than a non S KLR.
Since these ’89 chips are not designed for your configuration you can’t get the top performance of your car
Edit:
OK just saw you got a lot of mods on your car. If you are using chips designed for these mods, then you have no problems. Without the chips these DME & KLR boxes are the same on ‘88 non S & 89 cars
Edit:
