87’ 951 clock spring + horn diagram?
I’m trying to find this diagram in order to wire up my horn to work with an aftermarket steering wheel.
I have seen non-airbag car wiring diagrams but the wiring for the horn is different.
Any help?
Any help?
I think the black plug (brown/white) wire is for the horn.
Guess I could try to plug and unplug it to find out.
Feeling a little bit sketch becuse it’s airbag related.
Yes, the single wire is the horn - ground it to make noise
I took pictures documenting my conversion from an airbag wheel to a 968CS/930S? wheel and hub a while back - one thing you will need to do is install the wiper for the ring, and then add a mating connector to the harness (the socket has the pin but just blank, it's easy to wrap some solid wire around the pin). I can dig up the images if that's helpful.
My plan is to:
1. Drill the metal out in hole #71
2. Insert the “L” bracket / part # 928-652-104-00 / “wiper for the ring”
3. Use the momo hub
4. Ground horn button to the metal ring
I will find a small rubber washer/grommet to secure the “L” bracket / part # 928-652-104-00 / “wiper for the ring” in place.
Then run a 14 gauge(?) wire to the horn power plug / “add a mating connector to the harness”
Good idea about running some wire around the pin. Maybe solder wire?
OK - fewer pictures are useful than I'd anticipated, but here goes:
You'll need both 92865210400 and 92834709900 (get it used, about $30). Do not trim the tab on the latter (I learned that lesson for you with one very ill-considered cut!).
My control stalk assembly had the hole already, but if it's not there you're right. Lining it up might be difficult, so maybe use the harness connector as a guide? Anyway, should look like this:
I made a little pigtail w/a male quick connect at the other end, and hooked it up like so:
The rest you seem to have a handle on - it's pretty straightforward. The horn button should connect to both ground (some don't even have this and instead it's just the frame of the wheel) and the circuit from the wiper.
Also, your hub seems to have the wiper/cancel ring integrated! Lucky
L bracket installed. Easy to drill through the “71” hole
I bent a metal o-ring connector. Nice solid connection.
Wired up :-)
Can’t wait to get the interior put back together
Edit: oh yeah, you need the hazard button installed to get the turn signals working. That one had me stumped for a good 2 hours. Good ole search feature saved me.
four0four (12-15-2022)
