Oil drain plug with tap for oil temp sender?
I'm looking to install an oil temperature gauge and wondered if anyone knows of a source of a drain plug and thats been drilled and tapped to receive the temp sensor. Also my feeling is this is the most appropriate spot to measure oil temp since this is the oil that is being pumped ny the pump into the engine - any suggestions.
Thanks,
Skip
Thanks,
Skip
This isn't the ideal place to get an oil temp reading for. You want to read the temp of the oil that is flowing into the engine, which would be after the oil cooler. I will probably be tapping the oil cooler/filter housing if there is room. I can't be sure until I look at someone's car though.
Originally posted by BoostGuy951
Its Ideal if you want to keep an eye on your turbo oil temps. I think Ideally you would want one for each.
Can someone confirm for me the return line at the block, I think it is the side mount ?
Pump - filter - cooler - internals/bearings
Is this correct. I liked the drain plug because its measuring the temp of the oil that is being pumped by the pump, but if it goes through the cooler before it is being pump to the bearings then I agree with your statement.
Let me know what you guys think.
I am really surprised that no vendor has come out with a canned solution, both in terms of oil temp sensing as well as cooling for the 951's considering how many of them cars are tracked. I was talked to a buddy who is a total guru when it comes to American V8's and he was saying Chevy V8 blocks have a plugged tap at each main bearing as well as several other places on the block that are great to insert a sensor in. I't doesn't sound like our blocks have something like this which is surprising.
David,
I saw in doing some searches on this topic as well as oil cooling you had a stand-alone Mocal oil cooler without the stock cooler in place. Any experience with how this is working out on the track yet? I really would like to replace the stock cooler with a stand-alone cooler but am not sure what the best setup is yet.
Thanks,
Thanks,
Originally posted by Skip Wolfe
David,
Thanks,
David,
Thanks,
Thanks David. BTW what size cooler did you end up going with. Also what did you do with the coolant lines that went to the existing stock cooler?
Thanks,
Thanks,
Done With Sidepatch
I put mine in the oil return fitting/bolt, from the turbo, at the oil pan. I had an extra one and it was the easiest to drill and tap. Did it myself and no leaks ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
It probably isn't the ideal spot but the readings will be consistent and I have a WB02.
Thanks,
Thanks,
Stock hoses are out in the garage somewhere.
if one needs it I can sell a bolt with a hole that fits perfect to the oil drain hole and fits the NPT oil temp sender from VDO
Konstantin
Konstantin
