Oil drain plug with tap for oil temp sender?
I mean specifically, where on the filter plate does the return line enter the block, which line is it. I have a cooler plumbed in line with the stock one and I didn't do the installation, but I want to install a -12 temp sender block in the return line but I don't know which one it is.
Is there any reason why the Greddy oil filter block adapter won't work? I've test fitted the unit in my 86' 951 and it fit perfectly. I haven't had any reason to use it (the car is mostly stock). I guess I'm wondering if there would be any flow issues. Seems like it would be a simple solution to addin a oil temp sensor, oil pressure sensor. The block adapter has three plugs: M12 and a couple of 1/8pt.
http://www.greddy.com/products/produ...lock%20Adapter
-sean 86' 951
-sean 86' 951
Sean,
That is a very cool product. I did some quick checking and the 20 mm thread it has will work for our car, so as long as the o-ring is the right size - 2-5/8 according to Canton Filters website, and the o-ring is rated for the 5 bar oil pressure our cars see then there shouldn't be a problem. Anyone out there tried one of these.
Have you run the car with it or just test fitted it?
Good stuff- thanks,
Good stuff- thanks,
