What rotors do I have? And other part questions...
I was told that the car has big reds which looks like I do, but what 2 piece rotors are these?
What tubular arms are they?
What do people do for a bump steer kit with a manual rack?
Sorry but I bought this as a rolling chassis sight unseen, just pictures, with no real info besides the pictures.
Thanks all
Pete
Thanks all
Pete
Location: Formerly the DPRK, now seeking political asylum in Oregon
The discs -might- be from a 993 turbo.
Supposedly they fit using an '86 spindle (?).
'87 on, I know they don't fit.
Someone will be able to ID the control arms with some better pics.
LCA. my best guess, a race shop fabricated these with a hemi joint to mount spindle and adjust for camber. This fab is how race shops did things back in the day when race parts where not available from retailers. These are just fine. I would check the hemi joint spherical bearing for play and ability for misalignment from full bump to full bounce. Also check bolt used for attaching spindle to hemi joint, might want to replace if any question because a high stress area in shear. If replace, find 10.9 bolt made in Germany if metric or Grade 8 bolt made in USA if American Standard.
Post photo of the hemi joint/spindle attachment.
Lifetime Member
Lifetime Member
The rotor hats look like 993 Turbo (a picture from the side would help), but the discs are not 993 TT since they are not "drilled," so could be some type of aftermarket disc. I have a slightly used set of 993 TT rotors in case you need any. If you could supply a measurement from the face of the disc to the top of the hat I could compare to mine. As I recall, the difference in offset between 993 TT and normal 944 Turbo is about 5 mm. Since you are using adapters for the big reds that difference might have been accounted for in the design.
Thinking through my 993tt disc fitment issues... I forget which way they're offset compared to the 928 GTS discs that do fit.
I believe they pushed the caliper out toward the rim, requiring wheel spacers that put the rim outside of the fender (Nice look!).
If that was the case, then rims with more offset would allow 993tt discs.
Measuring the discs will tell. I have a brand new set on the shelf to compare!
Not drilled? Might be some brand of aftermarket?
I'd like to see some more pics of the car. looks like a nice project!
Nowanker (07-11-2021)
Lifetime Member
Lifetime Member
BTW, if anyone could use a new set of 993 TT size front brake pads I have a new set of Pagid Orange.
Lifetime Member
Lifetime Member
Nice clutch. Which one is it?
