need parts for turbo
Hey guys,
just had my k-27 rebuilt, it got the steam engine sindrome
now i'm looking for all the orings and crush metal ring that go in the turbo oil line and the manifold and downpipe.
were can i buy this?(thats not the dealership)
here ar some part #s
944 111 205 03 Turbocharger Outlet Flange Seal Ring
944 111 205 04 Turbocharger Inlet Flange Seal Ring
999 707 043 00 Turbocharger Supply Line O-Ring (top of turbocharger)
900 174 058 40 Turbocharger Oil Discharge O-Ring (between bottom of turbo and motor mount bracket)
999 707 043 00 Turbocharger Oil Inlet Flange O-Ring (top of turbocharger bearing housing)
Now are the first two the same for a k-27. i think this #s are for stock k26
TIA
TIA
Originally posted by 87uk944t
did u get they part#'s from clarks? cos i searched everywhere for 999 707 043 00 even on pet and it does not exist 999 707 043 40 is the only number close
If you double click the part number you will see the revision.
Contact Sunset Porsche: http://www.sunsetimports.com/porscheatcost.htm
Type in the parts you want and they will give you the total cost. They are fast and the cheapest source of Porsche parts anywhere since they sell them at cost.
You will have to replace all the exhaust rings that you took out... They are one-time-use parts. Also now would be a good time to replace the O-rings in the air/oil separator too.
