Proportioning Valve
Anyone just happen to have a pic or diagram of the proportioing valve location in an 89 951? I've pulled the rhs fender lining to expose the ABS controller, but still searching for the proportioning valve.
After knowing every damn fastener on the 911, learning this new car is frustrating!
Originally posted by special tool
It is screwed into the forward most driver side port on the master cylinder.
Isn't that a riot?
Isn't that a riot?
Tony I did mine but I don't really rmember I just looked at the new part I had and changed it. Here is a pic I hope it helps you.
![](http://forums.rennlist.com/upload/brake1.jpg)
Thanks guys - the replacement is coming on Monday, so it looks easy. Looking at the ABS controller and trying to figure out the plumbing, the lager cylinder on the inboard side looked like a candidate. The diagram closes it.
THanx again.
THanx again.
