Oil coolers - What are you running and how's it work for you?
For those of you that use your 951's on the track:
What oil cooler are you running? Where is it mounted?
How much power are you putting out?
Where are your oil temps/pressures at? Where are they being measured if using an aftermarket gauge?
Where are your coolant/water temps at?
thanks,
Adrial
thanks,
Adrial
On the new turbo there's a large Seatrab cooler. It's in front of the radiator. You can come check it out sometime if you want. Are you going to be at Lime Rock this week(Thurs/Fri)?
