Starter problems (I think)
1 Post
OK. So I added some water to the other cells as well. Let it sit for a few hours again I did the acidic test (is that what you call it in english?). Now all the cells are consistent but the tester says "recharge"!. So I put a charger on the battery and it peaks (12V). Could this be the battery after all? The battery (original Porsche item) is less than 2 years old, but the car has only been driven for ~1000 miles since then (PO is 68 years old).
How much water do i add to each cell? Should it be topped off? Each cell has a "cork" that screws about 1" into the battery. Should the water in the cells be as high as these "corks".
Eivind
Eivind
Originally posted by schnellfahrer
Where do I find something on the car that is ground? The head is alu, right?
Eivind
Eivind
The batery plates must be covered, but leave room for expansion. Adding water will reduce the charge. I doubt your battery is the problem, but you might want to have it tested at a shop. What you're doing doesn't tell you much.
Sounds like a ground problem or loose connection to me.
1 Post
Luckily, I had the same trouble when I tried to start this afternoon. I had a friend of my test with a multimeter while I cranked. He says there is no appareant problem with grounding. I tried to start 4 or 5 times and the car finally started. I guess this means that the solenoid is bad (??).
