Inside of Plenum looks like 40 grit sandpaper
My brother builds and dynos some of the highest flowing superchargers and intake manifolds in an internal combustion environment. Everything he has experienced in 25 years of doing it says smooth transitions and channels flow much greater volumes when laminar flow can be maintained right up to the transition point. In well tuned systems, that should be the valve bowl/seat.
That said, perhaps a turbulent flow is better for the engine characteristics needed for street use and not that of just raw power.
With that being said I suppose your brother has seen gains porting parts that were certainly badly finished to begin with.
I'm not going to go into proprietary information here, but smooth castings in an intake and head up to the valve bowl flow more than a rough cast or dimpled finished. If it didn't, you'd better believe that it would be implemented.
Again, different purpose and application over a street car so it's possible turbulent flow is better for street manners in various RPM ranges.
One of the reasons some guys cut open the mani is to cut down the divider between runners, which effectively shortens the runners and adds volume to the plenum which improves top end power.
Very true as the droplet size was like a thunderstorm and injection is like a fog. If you look into some of the flow techniques in direct injected engines, you'll find that laminar flows are desired so they can direct and initiate swirl into the combustion chamber rather than an uncontrolled tumble. Bowl and seat designs are very carefully designed and tested to direct flow as to best position the mix and flame front especially in lean burn conditions. The plastic intakes have close to mirror finish runners and the heads have very smooth ports.
My shop works on about 7000 cars a year and a large part of it is engine work. Pretty much anything made in the last 10 years has very little surface imperfections in the intake systems. We can all agree that power output is up significantly and fuel consumption is lower as well. That isn't from fast ECUs and fuel atomization alone.
The following 2 users liked this post by Perry 951:
odurandina (08-30-2020),
SirLapsalot (08-30-2020)
