Interior Door Handle Cable
So when I was putting my car away for the winter I went to get out of my car, pulled the handle and instant zero resistance and of course the door didn’t open. So I rolled down the window, opened the door from the outside, and finished putting the car away for the winter. Of course a sad day and I didn’t want to deal with the problem at that time. I pulled the door card today as the winter is coming to an end and I wanted it to be ready for the season. I discovered the cable came off some little **** at the latch assembly. It’s hard to see in there but I looks like the loop at the end of the cable just goes on this nub. It seems to work good, but before I put it back together, am I missing something? Should the cable loop be captured somehow to prevent it from popping off again? I didn’t see any broken bits inside the door that would indicate it is supposed to be.
Its hard to Explain but I will Snap you a picture and post... all I need to do is snap a picture of the one in my racecar.. (Doors are Gutted so its E-z to see rather than explain.)
Glen! Thanks! Looks like the end does just loop on and maybe it was just a fluke that it popped off especially over years of being pulled on. I guess I’ll do some probably much needed lubrication to the lock assembly and windows while I have things opened up.
