Rich, Rich, Rich (again...)
Not money, but fuel! I've been running a Guru chipset for the last couple of months and finally got the car onto a dyno with our local 928 Landshark group. Results on the dyno were pretty encouraging, except for the air/fuel ratio, which is extremely rich as soon as the boost comes on. Have a look at the attached dyno sheet - note - -it's in KW, not HP....where do I go from here?
Rob
Rob
Are you running enough boost? More boost=more air=leaner mixture.... The Guru v8 chips that I have are designed for approximately 15-17psi boost. I'm sure I'm probably running a bit rich right now myself as I'm still running about 14 where I had been with the Autothority chips making sure I didn't get too lean in the upper rpms. I have my LM-1 from Stephen (Thanks Stephen!) and need to get the bung installed so I can start monitoring mine. However since I'm in the position of possibly changing exhausts very soon, I am looking at waiting just a bit longer to do install that so I don't have to do it twice.
Are you still running stock injectors and wastegate? Looks like you're not running enough boost. Are you using a reliaboost or some other boost controller? Do you have an aftermarket boost gauge or any other way to measure boost accurately? When I got my latest set of chips from Danno I was quite rich (worse than you) because I was running 15 PSI and the chips were programmed for 17 PSI. My choice to run less boost so I had to tune the maps and drop some fuel out in the upper ranges.
I would also go with not enough boost. 160.6 kW = 215 rwhp. That is about what a turbo S makes at stock 11 psi boost. Those ships be pretty close to 12.5:1 if they were run at 15 psi boost.
Guys
Thanks for your comments - but -
Boost was recorded during the dyno run and was 17psi at 3500rpm, tailing off to about 13 psi at 5,500rpm. This agrees well with my vdo gauge readings
All settings are as per Guru chipset instructions, w/g is shimmed, Reliaboost is installed. Guru FPR installed. FQS is at position #0
Injectors are stock
Only other mod is 3" cat back SS exhaust
Rob (Schadenfreude) - PM me re Brisbane stuff if you want to catch up
Wayne - no electronic controllers used
Thinking of going back to the stock FPR and re-running on dyno - unless Danno has any ideas....
Rob
Injectors are stock
Rob
Don't go to the stock FPR, because you'll end being too lean in the anti-lag zone around 2500-3500rpm. You might be a little too tean in the upper-RPMs., but your 13psi at redline is less than the 15psi I anticipated, so you'll right around 12:0 which is OK.
The issue here is the 17psi extra boost I think. It causes the rich spot right as it hits because the extra boost increase the fuel-pressure on the FPR. I'll get you the latest version 18psi chip and you'll be fine. It'll take about a week to get down there..
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
