New seals, new oil?
Jane Bond 007
I'm replacing the balance shaft seals (and assorted o-rings) in the front of my engine. Are those the seals that do the major leaking in these cars? I want to switch over to Mobil 1 or Motul synth, but I've been apprehensive b/c of the risk of leaks. Think it's safe to switch once the seals/o-rings are replaced?
Here is just a bit of "information" for you Michelle(and I do agree with David) but; if you want to change, and again this is just information, you might try 3qts dino and 3 qts blend mix. Bob Miller, past PCA president, has a VERY fast stock 944 turbo that he tracks - a lot. His car was using oil and leaking after switching to synthetic. Someone from Castrol at an event told him to do the above and within 500 miles the car quit using/leaking oil and I actually talked to him about it, not just hearsay. Castrol and castrol syntec IIRC and he still runs it to this day...FWIW.
Jane Bond 007
Thanx for the help guys.
Ski:
I know Castrol makes a synth/dino blend. I like that idea, but may just stick with my high mileage Valvoline. I change it regularly enough that it does the job. Thanx all!
Ski:
I switched to Mobil 1 about 2 years ago and definitely noticed more leaks. If your oil leak is in the front of the engine behind the rear belt cover it most likely is balance shaft seals. If there's a lot of oil on the lower engine it could be the oil pan gasket or if toward the back of the engine the O rings at the rear of the Balnce Shaft housing(s). I'm in the middle of replacing all of these. HTH
