Fuel Pump Upgrade
Originally posted by NZ951
Lindsey just supply a bosch pump. its not a Lindsey pump as such... you can get it anywhere that sell bosch yeah?
I just dont like how tuners that supply parts get a name for it being "theirs" like the AFPR's or SS fuel lines its just where you got the item... Yes there is a point where it becomes unique, till then, it annoys me.
We carry both pumps. the "Lindsey " pump is 155$ and the 928GTS is 176$.
On thing to remember is fitment. Take a look at the following:
Fitting Length diameter
Stock 12mm 186MM 52mm
928GTS 12mm 180mm 60mm
Lindsey 15mm 203mm 60mm
(61942)
As you can see, the 61942"Lindsey" as an outlet bigger then our stock one, and the length is also bigger. whereas the 928GTS pump will bolt right in with better performance.
(61942)
Rennlist Junkie Forever
MySwiss
I'm not sure what you are referring to as the outlet, but the Lindsey unit will bolt right in with no modifications*
*Other than the outter insulation that must be removed from the stock fuel pump, and installed on the "lindsey" fuel pump... in which case I used a Dremel to cut it off, and spit it down the middle and reinstall.
But the fuel lines and electrical connections bolted straight up with no modifications.
TonyG
TonyG
J Chen
This is the exact fuel pump I have installed:
![](http://www.lindseyracing.com/pics/951fpump.jpg)
Here's the link to it on the Lindsey Racing web site:
Click HERE......
It bolted in with zero modifications.
For reference... here's the stock fuel pump:
TonyG
Click HERE......
![](http://www.lindseyracing.com/Merchant2/graphics/00000001/pumps.jpg)
TonyG
Originally posted by TonyG
J Chen
TonyG
J Chen
TonyG
I used the Lindsey and it bolted straight in without any changes as per Tony. It has been awhile since I put it in so maybe the current one is slightly different.
NZ951
>>>In summary, the "Lindsey" fuel pump is good for how many HP at what psi?<<<
I don't know what the capability is, but it will do at least 400RWHP at 2.5 bar with no problems.
I'm about to find out if it will do 435RWHP very soon. But I'm sure it will.
TonyG
TonyG
Tony. The "Lindsey " pump has the compression fitting that is 15mm instead of 12mm, the legth is 60mm instead of 52mm and the diameter is 203mm instead of 186mm.
Just stating the facts. I know it will fit, but the GTS pump actually is a closer fit to stock.
Duke. The web site is coming. as for the 172L/h pump , we also have it, but it's much more expensive. Like 337$.
