Exhaust POPs
Okay, so I was driving onto the freeway onramp while accelerating in 3rd, then some car gets in front of me, and I let go of the gas, and I hear a loud POP from the exhaust. I thought I'd experiment with this after I exited the freeway, and I did. Here's what I did, I gave gas in 2nd took it to 4k rpms, let go of gas, and I hear a POP. Then did the same in 3rd, and I hear another POP. Any ideas?
tia
tia
The way I've come to understand it is that there is still residual fuel going through the system after you let off the gas accelerating hard that comes out of the system into the exhaust and gets lit by the hot exhaust and sends a fireball back through the exhaust and occasionally out of the tailpipe. If you have a cat it pretty well covers it up by catching it, but cat-less (or gutted) it is much more prevalent. My brother has actually seen the fireball comes out of my tailpipe between shifts
Wish I had that on video!
Ok, my cat is pissing me off. My po changed it about a year ago, it's probably whats causing my no boost, and my ****ty MPG, and now this..
hmm..anyone got a step by step to remove the cat?
tia
tia
Yeah, step by step to remove the cat...
Get under the car and take off the 3 bolts holding it to the downpipe, the 4 holding it to the cat-back, the 2 holding it to the wastegate dump (it will slide forward off this) and the 2 exhaust hangers, believe 2 bolts on each hanger.
Originally posted by mochman
additional steps place on floor vertically and bash out all material use prybar etc. work from both ends it's a ghetto style test pipe but it works
seeing as I made more power on the dyno I got sheets somewhere with this method I still think it's worth a try. I've yet to hear of anyone making less power. BTW this was a temp. answer to collapsing cat then I test-piped it.
leaky injectors will also contribute to this problem. i had RC engineering clean/bench flow test mine and no more popping while downshifting. no free flow exhaust here...yet
Wait, you mean to tell me other states have emmissions too??? In California, as you may know, they are strict bastards. Stricter then ANY other state. Even PA! His car wont pass smog without the cat he has on there. Who cares if it looks like ones there or not. When was the last time a cop looked under your car? I was simply making a statement, not attacking your idea. that works in many states, but not here is basically what I was saying.
~Eyal
~Eyal
Uh didn't think you'd take it that way, what I was trying to say is a lot of us on this board run w/out cats even in cali. Also most test pipes bypass the cat so you're kinda back to square one anyway. BTW nice canyon pics
