Stock dwell map
Stock dwell map
Can anyone confirm if this is an accurate ignition dwell map for a stock 951, or alternatively can you post the correct one? I got this one from this thread but there was another incorrect one posted there too, and no one seemed to be able to confirm it.
Thanks!
EDIT: In case anyone finds this and needs the answer, yes it is correct. I extracted the map from the stock DME image and converted everything to milliseconds, and it matches up perfectly.
Thanks!
