Another Venturi question
I removed all of the venturi system last night. The steel tubes are gone. Is it ok to just run a 3/4 " heater hose straight from the crank vent to the intake pipe? I don't want to mess with a remote catch can right now.
Someone described its purpose on an older post. You can search for that or read my attempt to remember what it said. I believe the statement was that it was added to ensure that there was adequate vacuum(or pressure) to the power brake system. Perhaps Porsche noticed soft brake assist under heavy boost. I have not noticed any problems with braking after removing the venturi mess. I also have not driven my car in a race environment. Other racers, such as TonyG, report no negative effects from yanking the ventuuri.
