Help!
I am in Katy, Texas, just outside of Houston. I really appreciate the help. I usually read the threads , but do not post. However, this time around, I needed some actual dialogue. Hopefully, the test drive will go ok and it would have all been worth the effort.
biggles
biggles
How involved is it to rebuild (seals etc other parts?) a stock kkk turbo. Any other stuff to tackle while in there ? Not sure of turbo history but does have 150+k miles , consuming about 1quart every 1k miles , visual inspection shows oil coming from connections of exhuast ducting coming from turbo
Thanks,
Josh
Thanks,
Josh
Josh,
I did not do any work to the turbo itself at that time, incidentally just had it rebuild to a TO4E. Has not reinstalled yet. However, the reseal if you are leaking oil Aaround the turbo was not too difficult. There are instructions at http://www.clarks-garage.com/. Additionally, you can change out the vacuum, water, hoses etc and eliminate the old tubing under the IM.
biggles
biggles
