Fix leaks in car or pull engine?
Rainman
One word of "cautiion"...
once the engine is out and you can see all the other "hidden stuff" you will undoubtedly experience scope creep.
I pulled my engine out in July? for a simple swap, but my inner mad scientist took over...
I have been contemplating the same decision. Harbor freight has a hoist for $180 and a stand for $50.
Assuming i can convince she who must be obeyed to give up her side of the garage for a couple weeks (or months).. plan is to pull engine (out the top) do clutch and RMS, then put on stand for oil pan and bearings.
Will also address belts and water pump, and all front seals while out. Noticed a couple leaks from lower balance shaft cover...
Would also be a great time to figure out what I'm going to do with the 2.5 16v head in the corner.
Malcolm
Malcolm
Go to an auto body shop and buy yourself some "Pro Form" brand or similar Tar, Wax and Grease remover and or Final Wipe Solvent . It makes cleaning up the engine much nicer. A good spray bottle filled with this will also aid in washing away dirt, oil etc.
http://ca.proformproducts.com/en/pro...rease-remover/
http://ca.proformproducts.com/en/pro...lvent-cleaner/
Believe me when I say this stuff works as I have cleaned the hell out of the car projects I am working on using the stuff.
You use these product to clean before sanding and painting. It does not have to be Pro Form brand just any manufacturer that us used for cleaning before sanding and or painting.
Look at post #60 on my thread. Some of the dirt/oil was on the parts for well over 10 years.
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/864942-gruhsy-s-revival-of-rage2-s-old-car-4.html
I'll try to avoid it, but the temptation to pull that crank and find someone to offset grind it to make a 2.85 hybrid stroker is going to be strong. But then I'll need a MAF conversion and a bigger turbo...
68to86.. yeah the 16 v head needs to worked on - it came off a car where someone had not replaced the tensioner pad, so catastrophic failure. Setting that aside for now.
I just fixed my last exhaust leak and it pulling really well now. Reluctant to take it down for service, but that timing belt has to be addressed. I wil keep you informed of my progress (or lack thereof).
