Car stays in open loop.
#31
You might need a re-tune of your base map if everything else is good, but in the meantime you should break in your engine! The piston rings need to be seated in, which will improve engine compression/vacuum. Do that before obsessing over the base idle mixture, because that could change after the engine is broken in.
