Vortech C&L MAF Ford Mustang 80 mm 5.0 87-95 for 951???
Drive-by provocation guy
OK, in terms of wiring and tuning, what would need to be done to get this to work on 951. Also, it is already calibrated for our stock size injectors.
Todd,
Call up C&L and tell them what you have. To change the calibration on the C&L's for injector size (on a ford application) you change the pito tube attached to the inside the meter. Two screws. Tim @ speedforce uses a stock ford meter for his application so it should work provided you have something to adjust the signal for our application. Split second makes a product that is pretty slick.
Wow, and thats it?? How much tuning would you think???
what about the wiring to hook this up to the current a/f meter's plug??
