FS: Rogue tuning M-Tune setup
FS: Rogue tuning M-Tune MAF setup
Used Rogue M-tune. We ran this for the last 3 weekends on track before destroying our transaxle this past Saturday. We will be switching to standalone since the overboost fuel cut is set at 18psi pump gas/22psi E85 and our built 2.5L will be running well over that once the transaxle is back together. You will need 80lb Siemens Deka injectors (part number FI114992) which are available new for ~$40 each from most vendors and used for much less. Great condition. See photos. Air filter is super clean with no damage as are the silicone hoses. Chip is set for a 2.5L engine with the primary tune being pump fuel and the secondary tune for E85. $749
