New Rough Bock Pics - Deck Plate Engine
Rennlist Junkie Forever
For those of you that were asking, here's the start of my new engine.
Neal @ Performance Developments and Travis @ Castaic Motor Sports, and me (obviously) are working on the new project...
Here's what was a 2.7L block, rough, fitted with deck plates, and getting ready to be machined...
This is going to be close to a 3.3L or 3.4L engine when we're done with it!
Projected HP range is 500RWHP
Wohooooo
TonyG
![](http://www.tonygarcia.org/sleevemotor/1.jpg)
![](http://www.tonygarcia.org/sleevemotor/2.jpg)
![](http://www.tonygarcia.org/sleevemotor/3.jpg)
Wohooooo
TonyG
Originally posted by BoostGuy951
Care to share a $ figure for how much PD is charging for that deck plate? I'm very Interested since I have a 2.7 liter block as well.
Tony you are my "Hero"
Is there an advantage of using the 2.7L block instead of the 2.5L. Based on the picture, it appears that the stock siamesed cylinders were removed to install new sleeves and a deck plate. If that's the case using a 2.5L block will be just as good. Of course the 2.5L will need the windage holes that are cast in the 2.7l block.
fast951
You are correct on your assumptions.
I wanted a 2.7 block mainly because I plan to use a 16V head.
I've also got the factory piston squirters installed, both crank girdle dowels, and more tid bits......
What you are seeing is a rough photo. Wait until you see how we seal the head to the block..... no head gasket!
mu ha ha
TonyG
mu ha ha
TonyG
Originally posted by Eyal 951
um.... WOW! I'd like to reserve a ride once its finished! you taking reservations yet?
~Eyal
~Eyal
~Eyal
Originally posted by TonyG
fast951
mu ha ha
TonyG
fast951
mu ha ha
TonyG
I believe you will end up with something similar to the engine used on the DOOM car from years back.
So if no headgasket, do you plan on using the rings a la 930. So if the head lifts it continues to seal?
Interesting project, best of luck!
