Idle Issues
Idle Issues
Hi guys, I have an '86 944 turbo with an idle problem.
I just finished a big project where I replaced:
Any other components you think I ought to test? Thanks in advance for any suggestions!
- Timing Belt and associated rollers/pulleys
- Balance Shaft Belts and associated rollers/pulleys
- Front Engine Seals
- Vacuum Lines (including venturi delete)
- Exhaust manifold gaskets
- Flexible fuel lines to the rail
- Everything from the coil to the plugs
- Fuel pressure in specs at rail
- Fuel flow adequate
- Pressure drop from each injector is identical using tester
- Injectors cleaned out, nothing noteworthy in spray pattern
- Strong spark in each cylinder
- Good compression in each cylinder (for a cold engine, at least)
- Triple-checked timing . . . still good
- AFM & TPS check good
- ICV/ISV cycles with 12 volts applied
- Checked for vacuum leaks
I once replaced intake manifold gaskets and accidentally left an old gasket on one of the cylinders. I put another gasket over it. I had a slight intake leak and it ran super roughly and wouldn't idle just like you describe it... I would double check you don't have an intake vacuum leak. Put a slight pressure on the intake section and listen for air. Next I would check electrical connections once again.
Thanks for the recommendation, guys. I took the intake manifold off and triple-checked all the vacuum lines, and then performed a pressure test. I didn't find anything conclusive. Just a bit of leaking from the CV, which I gather is typical.
However, now the car won't start at all. No spark. Battery is fully charged, and I cleaned all grounds. Fuel pump is operating, and I'm getting good pressure at the rail. 12 volts are getting to the injector harness with the ignition on, Noid light remains stubbornly off when cranking, no fuel smell.
Interestingly, there's also no tach bounce, but I don't suspect the speed/reference sensors. They were allowing the engine to run before I did the pressure test. Resistance checked good, but I don't have a scope to test them further. They are also relatively new and I didn't mess with them at all in the previous work.
I'm beginning to think the DME computer is faulty. Any other ideas before I go down that road?
Thanks again for the assistance.
-Joe
-Joe
Does the boost gauge jump to "1" when you turn the ignition on? If not, that's a good clue the DME/KLR may not be getting power (check the relay?). If you have no tach bounce, I'd take a look at the speed/ref sensors anyway -- peek under all 4 rubber boots for signs of frayed wires. And/or wiggle them while cranking. The sensors may be new but the harness connectors are probably 30+ years old... I hear you that they seemed to work before, but no harm in inspecting under the boots...
gpr8er, I tested the ICV by cycling it with voltage applied to the different terminals. I heard good, positive movements from the internal valve. Didn't notice any leaking from the outside during the pressure test. Is there any way to check that further?
Tom, the boost gauge does indeed indicate pressure when I turn the ignition on. I'll mess with the sensor harness some.
Thanks, guys!
-Joe
Thanks, guys!
-Joe
If you have no fuel, no spark, and no tach bounce, then I would put all effort on that rather than ISV's, vacuum leaks, etc. If you like to play the odds, definitely check the speed/ref sensor harness. You might also open the DME and look for cracked solder joints.
If your car ran fine before your initial work, it seems these issues come from removing and replacing all that stuff. I'd say you've missed something during re-assembly each time (ex. plugging in a large vac line to the J-boot, plugging in a sensor wire, etc). There's always a lot of stuff to re-assemble. Been there, done that. It doesn't seem like you've got a bad part per se, certainly not DME or major part, assuming the car ran fine before the work
I would look at the speed/ref sensors, harness and DME/KLR as Tom mentioned. If your harness is not in the best of shape and you started moving the harness around chances are it may have broke a connection. Very common issue.
Check your distributor rotor. I had one have the screw back out and start spinning. It will still have spark, fuel pulse and everything tested out. Took off the cap and found the rotor screw loose in the cap. But I just read you don’t have fuel pulse now. Yep back to the harness.
Is your DME making the ICV cycle? Easiest way to check this is to turn the ignition key on but don't start the engine. If you can feel the ICV vibrating then your DME is making it cycle. If not, then you've probably found the problem.
