951 Engine Mount Replacent
I’m measuring between mount bearing surfaces. My car is at 55mm and anything less than 60mm = time to replace. Looks like time to replace though they appear not to be collapsed, no leaks. Engine vibration seemed fine, engine’s out now. Could I get by for a few years as they still look good or swap em?
id go with the LR Ultra Mounts if so. Thoughts?
They’re toast so why wouldn’t you change them while you have the engine out when it’s a lot more difficult with the engine in place. Also the stock Porsche mounts are far superior to any others, been discussed many times.
The engine, torque tube and transmission is one solid assembly on these cars, held to the body by only 3 mounts, if 2 are worn you are not experiencing the car to it’s best. Just a thought
