vacuum lines
There are the updated hoses from the intercooler pipe to the ISV, to the intake manifold. Brake booster to manifold hose. Oil/Air separator to intake boot. That is the system setup when you get rid of that metal venturi tube.
Yes that is correct Karl2bdc. We also supply the updated Idle stabilizer hoses(2),to replace the problamatic venturi tubes and all. we offer these OEM hoses for 32$..
It cleans up the underside of your intake manifold,prevents leaks and give syou better Idle an dresponse.
MySwiss. Do you have them in stock? If so I will paypal you on the 15th for a set of them...I could make them myself but I cam getting lazier with this car and I want it done THIS year!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Matt H We have the blue vacuum hose kits in stock,and we have an order of the Idle Stabilizer hoses comming in on the 16Th.
Let me know ahead,if you want some, that way I will keep some aside for you.
Yes, please order me a set of the IS hoses. I already have your vacuum hose kit.
With the IS hoses, it includes ALL the hoses necessary, right? If so you say 32 dollars? Good enough for me.
Well there you go, Myswiss should have all you need, just make sure you do it all at once. I would get a reliaboost and delete the cycling valve and venturi tube all together. If get the whole kit and need help with the install, just PM me or email me and i will answer any q's you have since i just did this.
Matt H The Idle stabilizer kit include 2 new OEM updated hoses. It's 32$ plus 5$ for shipping. You can Paypal me at steven.wistuna@ypg.com
i thought i was 1/2 for the brake hose and 3/4 for the oil/air seperator, but i could be wrong. I would have to go find the invoice, and i am far too lazy to do that
Thanks guys, MySwiss, PM box is clean (damn it fills up fast), and you have PM as well.
